Fog lights control head lights
Old May 16, 2019 | 07:59 PM
Richard Gary Pace's Avatar
Default Fog lights control head lights
Have a 2001 escape. Replaced headlights to Led. Fog lights now don't work nor the fog light switch light. Press fog switch and it turns on high and low beam lights. What is wrong
Old May 17, 2019 | 03:35 PM
What kind of instructions did you get with the replacement lights?
Did you get a complete kit or just decide to swap a few lights?
Old May 17, 2019 | 04:47 PM
I got lights that are suppose to be plug and play all built in to bulb. Head lights work. No high beam indicator now. So jump positive side low beam to fog light relay. That now activates the relay for fog light when low beams are on. Thinking maybe bad light head light switch.
Old May 18, 2019 | 08:38 AM
At the fog light switch I get 10.3 volts at battery 12.8. If I push the fog light switch it changes high and low beam. Now that I jumped the fog relay the only thing not working is the high beam indicator. The voltage to the fog light should be coming out of the head light switch. Not a loop through head lights.
cougar281
Jan 4, 2009 01:22 AM
95 Ranger
Sep 11, 2006 03:09 PM
jlfrnce
Jun 11, 2006 02:03 AM
budah77
Apr 26, 2006 03:11 PM
bigored
Oct 7, 2005 01:02 AM
