MAF ground issue
Old Jan 24, 2017 | 11:57 AM
mikebruce700000's Avatar
Default MAF ground issue
03 Escape 3.0. No power, received codes for both manifold o2 sensors running both rich and lean. I have tested the MAF sensor and found that there are no grounds, but does have power.
Anyone have experience clearing up the grounding issues?
Old Jan 24, 2017 | 05:45 PM
To confirm the ground is the only problem, the black with white tracer wire is the ground wire. You can run a jumper wire from the battery negative terminal to the terminal point where the black& white wire plug to the MAF sensor. This will provide a ground if that ground is incomplete. If everything is OK then trace the wire to where it is connected to a ground connection. Check that connection it could be off, missing or open. If that is ok then there may be a break in the black& white wire.
dishbound
Nov 4, 2010 07:33 AM
sean01
Jul 11, 2010 09:33 AM
eagront
May 30, 2009 02:04 PM
jeninejessica
Jan 7, 2006 12:41 AM
bbnx
Jun 11, 2005 10:20 AM
