my abs light is on
model: 2007 escape xls awd manual 2.3L
buy this cars for 2month, the abs light is on tonight, and I found the speed could not go up more than 60 mph when I drove on the high way.
what could be the problem? temperature is around 35f, snow,rain,ice...
or any idea how to check it?
There is a good possibility one of the wheel speed sensors could be defective. If possible see if there any codes in the computer and that might help direct you to which wheel has the problem. Places like Autozone, Reillys, and some other auto supply stores will check for any codes, usually at no charge. Get the code number(s) and post them here.
no error codes. (test with an Autel MaxiScan MS300 myself...)
only abs light is on. I parked the car for one night and the light was not on when I drove in the parking lot at a low speed. but it was on after my speed upon like 20~30 mph.
any idea, guys?
any idea, guys?
hanky is giving you excellent advise.
Another approach is to checking the wheel bearings for play and takin the wheel off so you can inspect and clean the sensor and the tone wheel (the part of the hub with the squarish teeth). Anything that may interfere with the sensor reading the motion of these teeth could cause a ABS light on.
I hope the ABS controllers on the Escape are better than those in the Windstar!
aangel
Jan 16, 2009 03:01 PM
rodav8
Jul 2, 2007 11:41 AM
