Parking lights wire?
Old Jan 13, 2011 | 06:59 PM
jasonohm's Avatar
Default Parking lights wire?
Anyone able to help me out with this one? I am installing a remote start system in my girlfriends 2010 Ford Escape and one of the wires I need to hook into is a purple with white trace which is the PARKING LIGHTS OUTPUT WIRE(POSITIVE OUTPUT). There are a lot of these wires in this color, I have probed several of them with the parking lights on with a voltmeter looking for the 12V positive, and have not yet been able to find it. Is there a distinctive spot to f ind it that it would be the only purple with white trace so that I can complete the installation? This is the last thing I have to do to complete....
Old Jan 14, 2011 | 12:31 AM
One sure way would be to access the headlite switch and locate the wire that goes to the front parking lites.
Old Jan 14, 2011 | 01:11 AM
jasonohm's Avatar
I have found the wire up at the front parking light and have confirmed that the color is purple with white trace, however, the wires go into the front quarter panel and come out somewhere in the lower drivers kick panel, just can't find where with all the bundles of wire down there.
Old Jan 14, 2011 | 01:21 PM
Sometimes it is prudent to just run a wire from the last place you see the wire you want and neatly tuck it in and bundle it with the rest. Also it can be quite a pain to work in the close quarters in a tight harness. It is usually easier to splice it in at an area where you can do a better job because you have more room to work.
Old Jan 14, 2011 | 01:28 PM
jasonohm's Avatar
I agree with you Hanky, but the only place I can find this wire is up at the parking lights at the front end of the car. Even if I splice an additional wire onto the one for the remote starter since it isn't long enough to reach there, will all the parking lights turn on like they are supposed to if I splice it into that one or just that light? I'm thinking they would since it should be a complete circuit, but am not sure, what do you think?
willy j
Oct 9, 2025 03:02 PM
waltfig
May 6, 2013 01:56 PM
ERG_90_Ranger
Jan 4, 2009 11:28 PM
country2
Apr 1, 2008 01:01 PM
bvahnee
Feb 14, 2007 11:36 PM
