Seatbelt 2nd row drivers side jammed 2011
Old Oct 2, 2021 | 02:36 PM
5umner's Avatar
Default Seatbelt 2nd row drivers side jammed 2011
The seatbelt won't release and gets tighter if the seat is folded down, meaning that you can't get it back up. I changed the mechanism from a junkyard car which worked perfectly until I installed it. There is some sort of release in the seat back latch but I can't tell how it works. Anyone know?
Old Oct 2, 2021 | 03:31 PM
scott.butler4's Avatar
You won't get it to retract unless its in the exact correct orientation as when the seats not upright. If you can figure out how to remove the seatbelt you can get it to retract then install it and see what the issue is.
Old Oct 2, 2021 | 03:37 PM
5umner's Avatar
I removed it and put in a new one, which worked before I put it in. There is a cable going to the upper backrest latch, but not sure how it works. I suspect the latch. Don't know where to find a diagram.
Sanddoc
Aug 2, 2021 08:51 AM
speekpe
Dec 28, 2017 10:16 AM
halubdesign
Oct 23, 2012 11:44 AM
CaptainJim32
Mar 19, 2011 03:32 PM
halubdesign
Jan 23, 2011 11:54 AM
