Traction Control and ABS lamps on again--the problem continues
Old May 20, 2020 | 08:29 PM
  #11
scott.butler4's Avatar
Originally Posted by cngizbleevng
I've replaced the sensor twice already and it hasn't solved the problem.
I know where the sensor's wiring connects inside the engine bay, but I haven't been able to figure where the wiring continues on from there. Where is this ABS module connector? Is it in the fuse box?
Its on the ABS module hence the name ABS module connector, the ABS module is located in the left rear of the engine bay, roughly below the brake booster. I have circled it in this picture.
As I said above the connector is weird and takes a few minutes to figure out how to disconnect, don't break it, when it is released it comes off easily.
Old May 20, 2020 | 10:08 PM
  #12
cngizbleevng's Avatar
I really appreciate your tips here! I hopefully will have a chance to look at this tomorrow.
Old May 21, 2020 | 01:05 PM
  #13
Ok, I think I found it at the back of the metallic box, but how the hell do you unplug it?
Old May 21, 2020 | 03:37 PM
  #14
Got it unplugged finally. Checked the resistance at each end of both wires and the multimeter never left the OL position, even though I tried it on several bits of metal and it went to 0.0 in most cases. The only possible glitch is that in the ABS connector, the openings were very small, and I wasn't certain I was getting the probes to actually contact metal. So I'm not sure whether I'm getting a bad connection (faulty wiring), or no connection due to the ABS plastic.
Old May 21, 2020 | 03:48 PM
  #15
They are small pins, you can get a small set of push pin adapters for multi meters at most auto store. Are you sure you were in the right pins on both wires?
I would try again.
Old May 21, 2020 | 03:58 PM
  #16
I can't measure any continuity on the wires either. The multimeter stays at 1.
  #17
I would try again.
OK, I'll see about that. Thanks. And yes, your instructions were pretty clear. I'm sure I had the right wires.
Old May 25, 2020 | 01:18 PM
  #18
Ok, so I received the smaller probe pins and each wire went from OL to 0.0 when I connected each end with the probes. When I touched the probes to each other the multimeter also went to 0.0.
I suppose that means the wiring is good there.
Old May 29, 2020 | 09:03 PM
  #19
OL means open circuit, 0.0 ohms means there is no resistance between ends of wires. Since you have now tested the wires and replaced the wheels speed sensors then the last part would be the ABS module.
Did you use a Ford Motorcraft speed sensor? I think if you jack up the front wheels and put the multimeter turned to AC voltage and plug in into the wheel speed sensor connector pins you should see a voltage when you spin the wheel, I dont know how fast you would need to spin the wheels though, I guess you could put in in drive with the front wheels off the ground, long as you secure the vehicle safely.
PlorkZ
Dec 29, 2019 02:05 PM
cngizbleevng
Nov 8, 2019 11:16 AM
Joey Harkins
Feb 16, 2019 01:58 PM
horton871
Sep 27, 2015 07:07 PM
ShawnNoffy
Jul 16, 2015 12:33 PM
