1998 ZX2 heat control
Old Jul 19, 2013 | 07:33 AM
twj815's Avatar
Default 1998 ZX2 heat control
My 1998 ZX2 has decided to stop allowing me to decide where the air comes out. It only comes out the defroster. There are no sounds in the dash when I turn the ****. The AC, blower speed and temperature ***** feel and do what they are supposed to otherwise.
My Haynes manual says nothing about this on the newer Escorts.
Am I looking for a vacuum or electrical problem?
Old Jul 19, 2013 | 03:39 PM
Because the system is designed to default to defrost mode with a loss of vacuum, suppose we start there. Look for a vacuum hose inside the vehicle that may have come off or may be leaking. If you can't find any inside start checking the hoses that go to the inside of the vehicle from the engine compartment. There should be a vacuum reservoir in the engine compartment that gets it's vacuum from a "T" or hose from the intake manifold.
Old Jul 29, 2013 | 06:27 PM
twj815's Avatar
Thanks Hanky, that was easy. Two little dried out and cracked hoses near the engine replaced and that problem was solved. I also replaced a few other cracked hoses and the engine runs smoother now, too. I am glad I didn't have to tear into the dash.
The next big problem will be to try to find the refrigerant leak in the AC system.
Use Common Sense
Jun 25, 2016 01:30 PM
opalgirl26
Feb 8, 2009 10:41 AM
escortjtc
Jan 17, 2009 03:23 PM
vic2121
Mar 30, 2008 01:59 PM
dfkeesee
Jun 5, 2006 01:50 PM
