96 efi engine
Old Apr 2, 2007 | 11:23 AM
jussike's Avatar
Default 96 efi engine
hi! i have a 96 escort turnier with 1392cm2 efi engine with an electronic ignition and i managed to snap its camshaft... now i´d like to replace the engine but it`s hard. i live in estonia (little country eu) there are many old escorts on the move here, but little with an engine like mine...
i have a running engine that fits on the car, but it is missing the electronic ignition system... it has a hole at the same spot on the cylinder block but whith smaller diameter and also there is no tooth (for the signal) on the camshaft
so my question is next: can i get this signal for ignition by any other means...
Old Apr 2, 2007 | 08:23 PM
goinstrong's Avatar
Default RE: 96 efi engine
I'm sure there is a way. Finding what system the other engine used you should be able to make it run and splice in your main harness.
Old Apr 3, 2007 | 10:34 AM
jussike's Avatar
the sensor i´m talking about is the hall sensor and the other engine hasn´t one..
the cam that snaped had a tooth for the hall sensor, but the other engine cam has a non-centered disc at the same place, with its higher point also at the same place as the tooth...
so if i make the hole in the cylinder-head bigger for the sensor, does it get a signal from the camshaft...
Old Apr 4, 2007 | 02:53 AM
goinstrong's Avatar
First you need to take a look at the fine reasoning behind what makes the sensor work. What is HALL efffect -and what makes it work MORE properly.
FordBling
Jul 3, 2015 06:43 AM
f250man
Apr 2, 2007 08:49 PM
bertus76
Oct 12, 2005 11:09 PM
oneoriginal
Sep 19, 2004 06:48 AM
mcgoolee
Apr 20, 2004 03:43 AM
