Car Hasn't Started For A Year = White Smoke?
Old Sep 10, 2018 | 04:56 PM
Taylor Moffitt's Avatar
Default Car Hasn't Started For A Year = White Smoke?
So I have a 94 escort that ran great up until the clutch completely wore out a little over a year ago. Mistakenly, I did not start the car during that period. Just a few days ago, I pumped all the old gas out, changed oil, sprayed some oil down the spark plug wells, and fired her up. She had a very thick cloud of white smoke for about 5 minutes, then it started to clear.
Its still smoking a small amount of smoke from the engine bay (I think its coming from under the heat shield), as well as the exhaust tip every time I start it. Weather is not too cold here, and it seems to be an issue even when warm. I haven't let it run for more than 10 minutes at a time. So far the oil doesn't look much different, maybe a little dark even though I just changed it.
So,
Do you guys think this is just water still built up from the car sitting for so long? Or should I not risk running it and take off the valve train to look at the head for any coolant leaks?
If it is a coolant leak, I don't remember it ever overheating before it sat for a year. So I'm not sure what would cause damage other than if I flushed the coolant wrong and caused it to overheat? I do also remember when I first started the car, it jerked real hard, and the oil pressure light came on. I shut it off quickly and checked the oil level, which was a quart lower than when I checked it prior to starting.
Thanks guys!
ByTheZ
Nov 19, 2018 06:03 AM
KenF
Oct 18, 2012 06:02 PM
RocktheJungle
Oct 2, 2011 07:44 PM
Fire Joe
Oct 30, 2008 03:25 PM
Rebel62
Jul 26, 2005 06:28 PM
