Changing A.T. Transmission
Old Dec 27, 2010 | 02:56 PM
jdspk's Avatar
Default Changing A.T. Transmission
Hi! I've changed alot of rear drive trannys but not FWD, I need to change 96 escort much different or not?
Old Dec 27, 2010 | 06:24 PM
In my opinion, very much different. Where you supported the engine from under the vehicle with rear drive, now you have to support the engine from above the engine. There was a cradle that had to be removed before you could remove the trans and it gets involved. The half shafts have to be pulled out of the transaxle, engine supported, starter removed, all the usual wires disconnected etc. If you are going to do this get a GOOD manual to assist you . To me, at least, it was like a night /day difference. Check with a disassembly instruction manual before starting the job and see if you want to tackle it. After you check the procedure let me know what you think OK ?
Old Jan 17, 2011 | 06:10 PM
jdspk's Avatar
Default Thank You
Hank I want to thank you for the info I did what you suggested, good manual and read. I changed it in 3 days. Your very right it is night and day. Again thanks
Old Jan 17, 2011 | 06:47 PM
Thanks for the update ! Glad everything went well !
repro
Mar 10, 2007 02:19 AM
trucklovingirl
Jun 27, 2006 02:56 AM
trucklovingirl
Jun 27, 2006 02:52 AM
trucklovingirl
Jun 27, 2006 01:38 AM
jwolfe815
Mar 31, 2006 08:30 AM
