erratic idle
Old Mar 18, 2018 | 07:46 AM
f150bft's Avatar
Default erratic idle
99 escort se 2.0 5-speed 140k sometime the idle will run up to around 2500 rps and hold some times it hangs around 12-1500 rpm and some times its normal. Can't see a pattern and I never know when its going to do it. I suspect an IAC motor but it is not throwing any codes. Looking for ideas or suggestions.
Old Mar 18, 2018 | 08:28 AM
You may not be seeing any codes because,
The computer thinks it is sending the message to the IAC and the IAC is supposedly responding, but mechanically it is not . The IAC possibly is sticking and the idle is erratic. Replacing it usually gets rid of the problem.
billburn
May 25, 2014 07:05 PM
garyward
Apr 2, 2011 10:19 AM
pl747
Feb 9, 2011 01:55 PM
pcampbell
Jun 1, 2006 12:54 AM
funkdoobiest
May 19, 2006 02:39 PM
