Intermittant Starting Issues
Old Jan 11, 2014 | 06:23 PM
maitai11's Avatar
Default Intermittant Starting Issues
Hi Everyone,
My girl drives a 97 Escort, 2.0 engine with an auto trans and just over 100k miles.
Recently, she started having starting issues. She turns the key and nothing happens. Not even a click. I told her to jiggle the shifter into neutral, and back to part, then try again.
Now, I don't know whether this is coincidental, but it's been starting up after she does that.
Are there any known issues with starting in these models? I'm thinking the linkage may need to be adjusted, or if there is a neutral safety start switch, that may be it as well.
Thanks in advance to any and all who help me figure this out. I am truly appreciative to whomever wants to play the "why won't it start" game.
I do not believe this is a battery or starter problem, but I could be wrong.
Please advise.
Thanks!
Maitai
Old Jan 11, 2014 | 06:45 PM
If she just tries to start it in neutral the first time , does it start OK ?
Old Jan 11, 2014 | 08:23 PM
maitai11's Avatar
Hi Hanky,
She is actually starting it in park, like usual. If it doesn't start, then she moves the shifter to neutral and back to park. Then, it starts.
Thanks for your inquiry
Maitai
Old Jan 12, 2014 | 05:55 AM
It is a common problem where the bolts at the bottom of the shift tube become loose.If you google, "shift lever bolts getting loose fords" you can see exactly what it is and an easy way to correct it.
Old Jan 13, 2014 | 02:01 PM
maitai11's Avatar
Thanks, Hanky:
Can you provide a link? Everything I have come up with relates to column-type shifters, and this one is on the floor. Any additional help would be greatly appreciated.
Maitai
dwarber
May 4, 2025 11:31 AM
bannthis
Jun 18, 2010 12:03 PM
detroitmi
Feb 3, 2008 09:01 AM
rlevy64614
Sep 9, 2006 02:16 AM
littlelady
Oct 7, 2005 05:04 AM
