erratic idle
Old 03-18-2018, 07:46 AM
f150bft's Avatar
Default erratic idle
99 escort se 2.0 5-speed 140k sometime the idle will run up to around 2500 rps and hold some times it hangs around 12-1500 rpm and some times its normal. Can't see a pattern and I never know when its going to do it. I suspect an IAC motor but it is not throwing any codes. Looking for ideas or suggestions.
Old 03-18-2018, 08:28 AM
You may not be seeing any codes because,
The computer thinks it is sending the message to the IAC and the IAC is supposedly responding, but mechanically it is not . The IAC possibly is sticking and the idle is erratic. Replacing it usually gets rid of the problem.
billburn
05-25-2014 07:05 PM
garyward
04-02-2011 10:19 AM
pl747
02-09-2011 01:55 PM
pcampbell
06-01-2006 12:54 AM
funkdoobiest
05-19-2006 02:39 PM
Quick Reply: erratic idle
