replacing the oil pan in a '99 Escort ZX2
Old Apr 2, 2013 | 04:17 PM
kpl1228's Avatar
Default replacing the oil pan in a '99 Escort ZX2
Kid drove over a hunk of metal in the road, ripped a hole in the oil pan. To replace it, what is needed besides a new OEM oil pan? Gasket? Or do i just use silicone? thoughts? It's the regular 2.0 4 cyl engine.
thanks all
Old Apr 2, 2013 | 06:42 PM
grindman's Avatar
you'll need a new oil pan and gasket if you need to use the sealer then do it as well it all depends on what kind of gasket you use if made of rubber then no sealer if cork gasket is used then apply thin bead sealer on both block and pan just make sure that it seals and doesn't leak
jbrianfoto
Sep 29, 2020 07:35 AM
jcasaccio
Oct 7, 2018 08:02 AM
carlzt
Jan 11, 2009 02:07 AM
Great White North
Aug 23, 2008 08:22 PM
1984/351W
Mar 20, 2006 04:57 AM
