08 Expedition rpm reader shaking
Old May 12, 2017 | 09:32 AM
Miguel121's Avatar
Default 08 Expedition rpm reader shaking
Hello Guys
if I am driving little bit under 2000 rpm and holding that spead I can see the rpm reader is jumping little bit up always and the car is shaking. Somebody maybe knows what going on.
Old May 13, 2017 | 07:07 AM
Before suggesting anything , it is important to know what kind of maintenance has been done to the vehicle.
Important:
how many miles on it
when were spark plugs last replaced
same for fuel filter
A defective coil(s) could be dropping out one or more of the cylinders causing a misfire
Sometimes something simple like poor connections at the battery can produce results like this. And yet, the vehicle has no problem cranking over to get started.
Your replies may shed some light on other possibilities.
Has the "check engine" lite come on at any time?
Old May 13, 2017 | 07:43 AM
Miguel121's Avatar
I just buy that Expedition. I do not have any maintenance history. The Carfax shows me just Oil and Filter services. It has 141000 miles on it.
No problems being starting, no cracking. No check engine light.
What you think I have to do the first step? Take a spark plug out?
Old May 13, 2017 | 12:49 PM
A lot of places that sell auto parts like Autozone, will check your vehicle for any codes in the computer usually for free. What we are looking for is any history codes (be sure to get the numbers) . It could be an intermittent problem not serious enough to make the check engine lite come on and stay on. If you decide to replace the spark plugs, so you know where you stand, with at least that much, I have found that "Motorcraft Brand" plugs gave the best service with Fords. It never hurts to get a second opinion from a good shop.
Old May 13, 2017 | 12:56 PM
Miguel121's Avatar
Thanks hanky for the information.
I will go today to Autozone and let him check if any Codes history available.
Old May 14, 2017 | 10:41 PM
Miguel121's Avatar
Not any failure codes. I starting to change the spark plugs out tomorrow. After than I will change all 8 coils out and I hope everything will be okay. I will post what happens.
Old May 16, 2017 | 09:07 PM
Miguel121's Avatar
Same issue after replacing the Spark plugs. Tomorrow I will replace the coils. Anybody know what else can be the issue?
Old May 17, 2017 | 07:09 PM
Miguel121's Avatar
Hey Guys after replacing the Spark Plugs and the Coil same issue. Somebody knows what else can be the issue???
Old May 18, 2017 | 03:20 PM
Miguel, you can't keep replacing parts hoping to hit the problem. Plugs ,coils,and fuel filter are normal maintenance items. Something like a can of "dry Gas" is cheap and might help, but the better thing to do would be to have someone with a good scan tool check the engine thoroughly. Just throwing $$$ at it doesn't always work.
cosmokramer
Nov 29, 2009 09:28 PM
915exp ford
Sep 19, 2009 01:31 PM
tygertone214
Nov 20, 2008 06:39 PM
tsi18psi
Oct 8, 2007 12:11 AM
kerwinq
Aug 10, 2006 12:18 PM
