1999 Ford Expedition 5.4 shaking
Old Apr 15, 2012 | 02:28 PM
bdiaz's Avatar
Default 1999 Ford Expedition 5.4 shaking
New here. Great site.
New plugs and coil packs installed two years ago. It is shaking upon acceleration and idle. Has lost a lot of power. I can floor it and it won't go over 70 MPH. Where do I start looking? It is not giving any codes.
Old Jul 27, 2012 | 08:51 PM
john15016's Avatar
Are you using Resistor style spark plugs? Sometines they fail and then will become delayed in their spark rate. Often seen in shifting with an auto transmission as shuddering and loping.
Old Jul 28, 2012 | 11:49 PM
bandit1948's Avatar
maybe the cat. converter is almost clogged up and causing too much back pressure ! if you changed the plugs 2 yrs. ago it might be time to change them again if you put a lot of miles on them ! did you check the motor mounts ? you might have 1 busted !
kal13
Mar 20, 2009 07:44 PM
gypsywitch1
Dec 29, 2006 11:02 PM
elizimah
Nov 8, 2006 02:49 PM
jr1017
Sep 10, 2006 03:27 PM
jk16201
Sep 13, 2005 04:04 AM
