2001 Ford Expedition
Old Jan 17, 2011 | 07:13 PM
yoshiko55's Avatar
Default 2001 Ford Expedition
My truck's battery light came on today so i took the battery to auto zone to have it charged and it is a good battery but when i put it back in my truck my battery light has not went off. I need help as to what it could be now that has the light still on? thanks
Old Dec 26, 2020 | 06:21 PM
CollinShelton's Avatar
Sounds like a fuse or wiring issue.
Old Dec 27, 2020 | 07:40 AM
scott.butler4's Avatar
The battery light indicates the charging system is not working not that there is a battery fault.
With the engine running check what the voltage at the battery is.
Old Dec 29, 2020 | 09:25 AM
A few side notes to keep in mind.
Some charging systems now use the PCM to control alternator output.
If you can when possible , get your replacement alternator for Fords, From Ford.! Some rebuilders just can't seem to get them right and when installed, the light still won't go out.
Usually a local alternator rebuilder will take care of your alternator and do a good job, plus if there is any problem , they are close to you.
Some charging systems would make the light go out even if it was charging only 1 amp. Of course this allowed the battery to get drained and go dead falsely indicating a defective battery. A better way to confirm charging is to measure the output (current -amps) under load. If an alt was rated at 85 amps, it should at least put out close to 85 amps when the system is loaded, A/C, defrosters , blower motor on hi , headlights on hi beam, etc..The reading will usually drop down after a few minutes of charging.
stevied71
Aug 5, 2009 09:53 PM
BASSHAWK
Jan 29, 2008 07:17 PM
WifesEscape
Apr 28, 2007 03:50 AM
TK
Jan 24, 2006 10:37 PM
Rebel62
May 2, 2005 05:24 PM
