2003 surging issue
Old Apr 3, 2023 | 09:33 AM
Chambr's Avatar
Default 2003 surging issue
My 2003 Expedition 4.6 is experiencing surging ... i replaced the injectors ,,, coil packs ,, cleaned throttle body ,,, changed air temp sensor and mass airflow sensors .... Thought on why this is happening? See video attached to hear the problem ...
Thanks in advance
-Mike-
Old Apr 3, 2023 | 11:33 AM
First, couldn't access your link.
My second question is related to the description of the problem.
There are a few things that can produce surging.
We need to know at what speed , accelerating, decelerating ,cruising. What do you do to eliminate it or reduce it?
Did you have the vehicle checked for any codes?
You didn't mention spark plugs, which may or may not contribute to the problem.
Does it happen more when the engine is cold or warm?
Old Apr 3, 2023 | 12:13 PM
Chambr's Avatar
I am not sure why the attachment didn't work .. I changed the format of the attachment to WMV ... hopefully that'll work ...
This is happening at idle both warm and cold.
Plugs were replaced as well as the O2 sensors ...
Old Apr 3, 2023 | 12:47 PM
Did you check the EGR valve for being clean so it can fully seat and not allowing exhaust gas to interfere with mixture info that the oxygen sensor is sending to the PCM and it keeps trying to correct?
Old Apr 3, 2023 | 12:58 PM
raski's Avatar
I suspect a vacuum leak or a fuel pressure issue causing a lean mix.. Connect a scan tool with live stream capability. Looking at the fuel trims will give you some direction and a highly positive reading would verify a leak or a fuel pressure problem.
Old Apr 3, 2023 | 02:12 PM
Chambr's Avatar
Now thats 1 thing i did not check .... ill do it in a few days and let u all know ....
Chambr's Avatar
I checked for vacuum leaks and none were found ... gonna ck the egr valve and see then deeper we go .... Thanks
nikoford306
Aug 5, 2021 12:34 PM
chrisyeary1989
Jun 22, 2021 06:40 AM
Mark Crabtree Sr
Oct 22, 2018 09:51 AM
Iluvya Barriere
Dec 12, 2017 05:41 PM
krpickey60
Jan 18, 2012 07:31 PM
