2004 Ford Expedition
Old Jul 29, 2010 | 04:00 PM
terrymaher68's Avatar
Default 2004 Ford Expedition
Whenever I put my Expedition the engine cuts out. When its in drive all is good but if I stop and put it in Park then then it starts cutting out. Any idea what the problem could be?
Old Jul 29, 2010 | 05:11 PM
Default Check Engine
Now my check engine light is on.
Old Jul 29, 2010 | 08:03 PM
A good start would be to have the reason for the C/E lite coming on. Some auto supply stores will do this for you. Get the code in the computer and go from there. Please remember, the code doesn't always tell you the exact cause only which system is causing the problem(s). ,,,,,,hanky
Old Jul 30, 2010 | 10:52 AM
The only thing is now it will not idle. Even in drive. you have to constantly be giving it gas. If you remove your foot from the accelarator wether in park, neutral or drive the engine cuts out.
Old Jul 30, 2010 | 09:36 PM
I connected a code reader to it and got the following
P0506
Idle Control System RPM Low
Any ideas? Some one told me it may be the Idle Air Control Valve.
Old Jul 31, 2010 | 05:52 AM
Before you go to replace the IAC valve, why not try this? Check the entire intake system for any leaks (vacuum hose off or leaking) including the air filter itself. Just start at the point where the air comes in for the engine, and trace the system all the way back to the throttle body. We're also checking for any plugging (obstructions).
Old Jul 31, 2010 | 08:49 AM
Forgot to suggest; check the throttle body for dirt. Use a clean rag ang make sure the passage and throttle blade are pretty clean.,,,,,,hanky
cew1234
Apr 28, 2014 02:34 PM
Ellobo88
Apr 17, 2014 07:06 AM
95z115
Oct 27, 2007 11:10 AM
BlindFordUser
Mar 18, 2007 02:37 AM
Jville808
Feb 26, 2007 08:54 AM
