99 EB bad brakes or?????
Old Apr 10, 2006 | 03:11 PM
jame04's Avatar
Default 99 EB bad brakes or?????
Hello, I own a 99 EB Expedition. A few weeks back it seemed like my brakes were locking up so I replaced them all around. The symptoms were that when I would make sharp low speed turns it felt like I was in low 4 wheel drive, jerking and even stopping the truck. Now that I replaced the brakes it is still doing it. Can it be something in the transfer case or??? thanks.
Old Apr 12, 2006 | 04:45 PM
fivewt's Avatar
Default RE: 99 EB bad brakes or?????
It's probably a fuse in the ABS system.
Old Apr 14, 2006 | 12:45 PM
jame04's Avatar
not the fuse, so I am going to check the rear speed sensor???
Old Apr 14, 2006 | 07:37 PM
jame04's Avatar
replaced the rear ABS sensor and the ABS light went off but did not fix the orignal problem???
Old Apr 20, 2006 | 12:37 AM
frdtek05's Avatar
There's a tsb on replacing the clutch packs in the rear diff on those. Tire chatter/binding while making turns.
Updated parts
Old Apr 26, 2006 | 12:37 PM
jame04's Avatar
well I took it to my local mechanic and he is saying that it is locked in 4W drive all the time but he is not sure why. He says the motor is running fine so he doesn't think it is ecletrical. He thinks it is internal and that is not his expertise. I guess my best bet is to take it to the local Ford dealer???
MrSauga
Sep 19, 2012 04:26 PM
rlpatte
Mar 31, 2012 08:45 PM
POOPSHOOTER
Sep 26, 2005 12:32 AM
xkikbxr
Jul 15, 2005 01:34 PM
stableboy06
Feb 28, 2005 07:23 PM
