AC compressor not coming on
Old May 11, 2018 | 01:01 PM
shorby12's Avatar
Default AC compressor not coming on
We checked everything up to the Relay by the radiator support. Relay is good, we can make the compressor come on by placing power on pin 30 where the relay plugs in. I am needing a wiring diagram to trace from the relay to see why no power is getting there. Thanks
Old May 11, 2018 | 01:02 PM
shorby12's Avatar
On a 2004 ford expedition edie bauer 4wd.
Old May 11, 2018 | 05:31 PM
Use Common Sense's Avatar
Just out of curiosity, have you checked the refrigerant charge in the system? A low charge will keep the A/C compressor from engaging. What is the static pressure of your system?
Old May 14, 2018 | 08:05 AM
shorby12's Avatar
We checked system it is full of freon has correct pressure....only 3 to 5 volts at compressor and at the relay by radiator we can put powet there and compressor comes on...i am looking for the wiring diagram to see where the power comes from tjat goes to the relay by the radiator thanks
Old May 14, 2018 | 11:20 PM
OK...I like to start with the easy stuff since it wasn't mentioned. I don't have a wiring schematic, but you might be able to borrow one from your local Ford dealer. Their's is probably collecting dust since the Freestar/Monteray are 11 years out of production.
shpbling
Mar 1, 2010 04:18 AM
mystarcollectorcar
Feb 6, 2010 01:38 AM
smokinjoe909
Jun 28, 2008 03:27 PM
dan007nj
Apr 11, 2008 12:02 AM
Naked and Famous
Feb 27, 2008 03:45 PM
