Engine idling rough/ stalling at stop.
Old Dec 2, 2019 | 09:32 PM
WildHammer's Avatar
Default Engine idling rough/ stalling at stop.
97 5.4 260,xxx. Pulling lean codes for both banks and a p0401 EGR flow. Truck is idling like crap and stalling when I slow down or stop. (Occasionally) new fuel filter, new fuel pump, new air filter, new maf sensor, new o2 sensors. Can’t find a vacuum leak anywhere, sprayed entire engine in carb starter and had no effect. Need help
edit: engine does smooth out when I give it some gas.
Old Dec 3, 2019 | 01:18 AM
I would suggest that you remove and check the EGR valve for being full of carbon and staying open. Sometimes a few raps on the exhaust end with a MALLOT ,will dislodge the piece of carbon and allow the pintle to seat and close fully.. Get a new gasket before removing the valve , you might need to replace it.
dankris007
Feb 9, 2016 10:09 AM
McStein
Feb 3, 2012 08:01 PM
rdonaphon
Sep 16, 2010 11:36 AM
jhuntco
Sep 25, 2009 04:46 PM
phatcat
Sep 26, 2006 08:23 PM
