Just wondering
Old Jul 18, 2018 | 04:50 PM
Mbc's Avatar
Mbc
Default Just wondering
Is there any way to test a suspension solenoid on a rear wheel of a 07 expedition 2wd
Old Jul 18, 2018 | 05:28 PM
Yes, there is !
There are at least 3 electrical checks you can do if you use a volt/ohmmeter .
The first would be to check if the ground connection is good.
The second would be to check if power (usually 12 volts) is getting to it when it is supposed to operate.
The third would be to check for continuity (specific ohmmeter reading) across it's terminals.
Then there are mechanical checks to check
If the solenoid is supposed to allow air pressure to pass when activated, you might hear it operate, but not open the passage to allow that air to pass. Confirmation needed.
And the reverse also needs to be confirmed, is it supposed to allow air to pass, then when activated prevent air from going through.
A lot depends on the application and what it is suppose to do.
This may not answer your question specifically, but if you know what is supposed to happen the above info should provide some type of guide.
Old Jul 19, 2018 | 08:41 AM
Mbc's Avatar
Mbc
Default In appreciation
Thanks hanky. I appreciate all the info.
gravis346
May 6, 2025 06:50 PM
newjerseyjohn
May 21, 2013 08:21 AM
marvin1987
Jun 21, 2009 10:59 PM
forsan
Mar 2, 2007 11:32 PM
budlight
Feb 2, 2007 02:25 PM
