No crank, No obd2, blinking theft light
Old Nov 18, 2022 | 02:02 PM
beer82's Avatar
Default No crank, No obd2, blinking theft light
2007 expedition. 5.4 v8
Wife went to start car, made it a few feet, acted up and threw the wrench on dash.
i check the obd2 data, comes up with codes
p0135, p0155, p0443, p0010, p0020, p0102
p0135
I clear the codes, they all come back. Open the hood to start checking fuses, notice the wiring harness that goes to a couple 02 sensors, and the transmission has landed on exhaust and burnt a few wires.
I remove the harness, fix the wires, put the harness back in.
​​​​in.Car starts but throws all the same codes. Take the harness back out thinking i messed a connection. ohm meter them, they a have continuity. Put harness back in.
Go to start the car, dash comes up showing kms for a split second, then dashes for kms, fast blinking antitheft, wont crank over, also now obd2 wont pull codes(powers up scanner though). Then changed out blown fuses 70 and 74 under hood. still nothing.
Old Nov 19, 2022 | 10:28 AM
Difficult to diagnose over the net.
Suspect there is another open somewhere that supplies power to the above components resulting in the codes.
Lets hope it is only an open somewhere and not a damaged PCM.
This is a little out of your hands without a diagram and understanding of how the affected components operate.
You might consider having a qualified shop check it out..
Aspen0524
Sep 24, 2020 06:00 PM
fastonraceday
Dec 29, 2019 05:41 PM
tennesseesaturn
Aug 31, 2011 06:15 PM
helpmyford
Apr 8, 2010 10:27 AM
Vladtepest
Nov 12, 2007 05:55 PM
