1996 explorer cruise control not working
Old Dec 23, 2019 | 07:58 PM
Onewirenut's Avatar
Default 1996 explorer cruise control not working
is there a diagnostic fir this?
Old Dec 24, 2019 | 02:28 PM
If your vehicle has a switch located on the brake master cyl , check that sw. When brakes is applied it cancels cruise. If sw is stuck it will not allow cruise to set.
Old Dec 24, 2019 | 10:22 PM
Like hanky mentioned, could be the canceling switch fail or it’s connector for corrosion etc.
There’s not much shop info on system diagnosis available, but there is a schematic available to check steering wheel switches, Clock spring, harness on down to the pressures switches as well as the servo unit. With a schematic, you could check for input/output and prove out circuit functions as part of a diagnosis..
Glennp
Jan 3, 2015 10:30 AM
rod525
Nov 4, 2014 03:36 AM
Ben Johnson
Nov 26, 2013 09:43 PM
david paul
Nov 29, 2007 11:14 AM
ChipF47
Jun 4, 2006 09:15 PM
