2003 Questions/Problems
Old Sep 4, 2008 | 07:42 PM
03ExploKRV's Avatar
Default 2003 Questions/Problems
I just bought a used 03 Explorer with 29k miles for a second vehicle. I noticed the shift lever is kind of tricky getting back up into the park position. Is there a trick to this or something or is the shifter faulty?
Also, I have the back up sensor thingy but the switch on the dash stays in the "off" position all the time. I try to switch it back to on but it switches right back off again. This did work when I bought the vehicle. Anyone know what may be up? The sensors on the bumper are clean and unobstructed.
Thanks in advance!
Old Sep 12, 2008 | 12:05 PM
03ExploKRV's Avatar
Default RE: 2003 Questions/Problems
For anyone here who may be interested. The dealer told me some kind of solenoid on the brake pedal was bad and that is why the shifter is not going into park like it should. They ordered a new part, free of charge, to fix it!
Also, the back up sensor problem, one was bad but they need to replace them in pairs. He ordered two again, free of charge!
Old Sep 12, 2008 | 07:02 PM
Thanks for the update...
The shift interlock solenoid is a fairly common problem. Also,, there is an access hole on the under side of the column covers to manually release the shifter should it be needed..
Glad they took care of you..
Old Sep 14, 2008 | 12:42 AM
ricksteel's Avatar
I backed out of the driveway and my 2002 explorer quit running. I tried to start it and the starter did nothing. I troubleshot it and if I bypassed the PCM the starter would turn over but no starting. Anyone have any suggestions?
wes029
Apr 27, 2011 05:38 PM
99fordguy
Mar 22, 2011 06:15 PM
ChaoticAppleSauce
Sep 11, 2008 11:36 PM
burnt_toast
Aug 19, 2007 10:53 PM
karguy427
Nov 28, 2006 04:32 PM
