2013 Ford Explorer Rough Idle when A/C on
Old Sep 27, 2025 | 01:06 PM
  #11
myangelaware@55's Avatar
Hopefully, this is what you're requesting. NOTE: I am a female that does not normally know what cha may or may not need. With that said, bear with me & when you indicate what exactly you're looking for; I might be able to understand the request. Thank you!
U0401-68 - Invalid Data Receield From (ECM)(PCM) A - Event Inormation
C0004-49 - (TCS) Control Channel B Valve 2 - Internal Electronic Failure
U3000-49 - Control Module - Internal Electronic Fallure
C1137-64 - Reverse gear switch - Signal Plausiblity Fallure
U3003-16 - Battery Voltage - Circuit Voltage Below Threshold
Old Sep 28, 2025 | 03:01 AM
  #12
Thank You for the info.
As I see it, there was a power supply problem that may have all been corrected with the battery replacement.
Unfortunately, increasing the power available does not always correct problems with poor connections which could still be present.
We need to know what codes , if any, are present NOW.
Codes used to be erased by just disconnecting the vehicle battery for a period of time. On some vehicles the codes cannot be erased that easily anymore and the vehicle MUST be run through a particular cycle matching the conditions required before the codes will go away .
What it is saying , the repair must be the correct one or the problem is still present.
Old Sep 29, 2025 | 07:06 AM
  #13
Thank you.
As Noted, the Explorer is my Daughter-in-Law's & they are getting ready to leave for Vacation & have since rented a Vehicle for their trip. Of course, we have not taken it back to the 2nd Opinion person to have the Codes ran again. However, the Battery had been replaced when He ran it the first time & those Hard Codes existed from the computer's memory. As soon as I am able, I will try & get the Explorer back to the gentleman that ran them for me, to see what appears now. The Mechanic that worked on the vehicle initially, was 'our' mechanic & we feel a bit responsible for these issues still existing, since we referred him. Of course, no one is perfect at their craft, but we feel badly since they've spent nearly $4,000 in repairs in the past 16 months. We're hopeful that we can find a resolve for these issues, especially since this is her daily driven vehicle for work & transporting our Grandchildren.
Your advisements have been appreciated & I'm sorry that I wasn't more helpful in my understanding. IF we can find out more Information a bit later, I'll be happy to post what I learn, if that's okay. Thanks again.
Old Sep 29, 2025 | 12:45 PM
  #14
Thank you for the update.
D WILSON
Nov 1, 2019 11:39 AM
Inlovewithnight2
Jul 6, 2018 09:58 AM
bmackinlay
Jun 5, 2014 01:47 PM
trev0006
Jun 6, 2012 01:20 PM
tbo3374
Jun 3, 2012 09:17 PM
