95 explorer no start
Old Feb 18, 2011 | 12:48 PM
joeyt's Avatar
Default 95 explorer no start
I got a 95 explorer and just put a used engine in it old one blew. i double checked everything to make sure it was hooked up. engine cranks but no fire or fuel i checked fuses and fuel shut off but all are ok. need to know about any antitheft or possiable solutions. thanks
Old Feb 19, 2011 | 02:50 AM
It would help if we knew whether you were getting spark and/or fuel.
Old Mar 1, 2011 | 07:32 PM
khiks's Avatar
i encounter that trouble before here are some few tips,check the pressure of fuel,cause may be it's the same trouble that i than before i change the fuel pump,but if you think that the fuel pump is good,check the timing of the engine,check the crank shaft sensor.
makuloco2000
Oct 22, 2013 09:46 PM
mayor
Nov 18, 2012 06:46 PM
NYCArmyWife
Nov 16, 2008 12:29 PM
iownslaves
Apr 1, 2008 06:03 PM
Ranger96
Jan 27, 2007 06:18 PM
