Belt tensioner basics...
Old Jul 30, 2009 | 07:54 PM
swaman's Avatar
Default Belt tensioner basics...
Hi gang!
Could someone please explain to me how to relieve the belt tension on my '98 SPORT?
I see no way of prying it, and when I attempted to use the bolt on the front of the tensioner to rotate it in the direction that is molded into the assembly, the bolt began to loosen, so I stopped.
I was concerned that if I continued to the end of the bolt, the tensioner would come out of therelike a bullet zeroed in on my nose!
Any help would be greatly appreciated!
Thanks!
Frank
Old Aug 1, 2009 | 12:45 PM
swaman's Avatar
Aaaaaaallrighty then. NEVERMIND!
Old Aug 6, 2009 | 01:39 PM
Use Common Sense's Avatar
Sorry for missing this one...If you haven't already figured it out, you should see a square hole in the belt tensioner arm. This is where you place a 3/8" drive rachet. You swing the arm in one direction or the other to pull the tension off of the belt for replacement and installation.
jec65
Oct 20, 2019 08:33 AM
black95gt
Mar 30, 2007 01:41 AM
BobCT
Mar 25, 2007 12:52 AM
Mr.T
Sep 8, 2006 12:13 AM
AlphaMan
Dec 5, 2005 12:24 AM
