check gauge light
Old May 13, 2005 | 01:51 AM
spinning wheels's Avatar
Default check gauge light
CHECK GAUGE light is on at dashboard and coolant gauge reads too high with no apparant heat issue. What gives? Any suggestions Ford Brainiacs? Can I repair myself? This is on a 2000 Explorer XLS with v6 automatic.
Thanks in advance!
Old Jun 3, 2005 | 03:08 AM
techman's Avatar
Default RE: check gauge light
SOUNDS LIKE A SENDER UNIT PROBLEM, TRY UNPLUGGING SENDER TO SEE WHAT HAPPENS TO THE GAUGE. DID THE NEEDLE FALL? TRY SHORTING THE CONNECTOR PINS TOGETHER, NOW DOES IT FALL? IF YOU NEED HELP ON WHERE TO FIND THE SENDER, JUST REPLY.
allensimpson
Jan 10, 2008 09:40 PM
77Bronco
May 9, 2007 12:51 PM
killgore101
Nov 2, 2006 11:41 PM
Cougar_Vibe
Mar 12, 2006 08:29 AM
