Having trouble with RX and TX wiring. i have no clue.
Old Nov 7, 2020 | 09:19 AM
Tommy Knight's Avatar
Exclamation Having trouble with RX and TX wiring. i have no clue.
I have a 2001 ford Explorer 4.0l 4x4. I'am rewiring the motor harness on the 2001 ford explorer to have a 2003 ford ranger PCM. Because i dont want to do the full wiring swip in the cab or rest under the hood.
So i did a swip on the Explorer to a manua from a Auto transmission. I have 50% of the wiring done. Then ran into a problem on the 2003 ford Ranger wiring diagram for the
PCM pinout on the
#17 is GY/OG wiring is for "RX,signal"and the#18 is WH/LG wiring is for "TX, signal".
Now my 2001 ford Explorer motor wiring harness dosen't have the #17 not in use. But the #18 pinout dose have one. But not the WH/LG but it does have a BK/WH wire thou.
I dont know what to do since am using the 2003 ranger PCM and Not the 2001 ford Explorer PCM.
I added a Attchment to My PCM Diagram am using on the 2001 ford explorer. The yellow boxs # 17, 18 is the one am having trouble with.
The red boxs is the wiring i have remove for the Auto transmission wiring am not using
and the Green boxs is for the wiring am added to the Manual transmission to the PCM.
Old Dec 21, 2020 | 02:16 PM
Lincoln_Luc's Avatar
PCM pinout on the
The RX & TX wires are for the PATS system(transponder key). Those wires leave the key barrel and make their way to the PCM. Not sure if you will need to program a new key to this or what though.
Tommy Knight
Oct 28, 2020 10:28 AM
Tommy Knight
Oct 28, 2020 02:44 AM
Tommy Knight
Oct 28, 2020 02:39 AM
MHH777
Sep 27, 2018 07:35 PM
corvairbob
Aug 28, 2005 03:39 PM
