HELP, PLEASE
Old Oct 6, 2007 | 05:50 PM
fisherman's Avatar
Default HELP, PLEASE
Am working on a '91 Explorer and have discovered gasoline in the oil. Can anyone tell me why or how this could have happened?
Any help is greatly appreciated!
Robin
Old Oct 6, 2007 | 10:27 PM
Tony R's Avatar
Default RE: HELP, PLEASE
when you drive your car is it getting up to opperating temp? If you are only taking it for short drives and it stays coldyour engines rings dont work properly and you will get fuel seepage into your crank case. It is a more common problem on the V8s and 6s than on the smaller engines.
Old Oct 16, 2007 | 07:29 PM
onelap's Avatar
comming from the intake probably thru the carb or manifold area..check carb? for sticking float if carbutated..
LakelandF150
Mar 25, 2012 08:57 PM
llazarus10
Mar 7, 2011 05:33 PM
Adhd
Feb 3, 2008 09:55 PM
davequest
Sep 12, 2006 04:16 AM
