I have a 2015 explorer sport 3.5L T/C looking for fuel pressure sensor location
Old Oct 7, 2022 | 11:07 PM
wundrgrl77's Avatar
Default I have a 2015 explorer sport 3.5L V6 TT looking for fuel pressure sensor location
Edited to add: located under intake manifold 🤢 Thanks Ford 🙄
Does anyone happen to know where the fuel pressure sensor is located? I want to change it out in hopes that my issues aren't my fuel pump! I'm getting codes P0087 and P008A/P008B. It is Intermittently, usually when merging on the highway, stalling out. I give it gas and it wants to die, then it will stop and I can drive fine again. Triggered check engine light. Then it went off on its own. Then it really stalled out, shut it off, restarted it and off I went? Weirdest **** ever!
Last edited by wundrgrl77; Oct 8, 2022 at 09:03 PM. Reason: It is a twin turbo which could make a difference
Old Oct 7, 2022 | 11:20 PM
raski's Avatar
I doubt it's the sensor. Sounds like it's doing its job. You are experiencing your problem mostly when the engine is under peak demands and the sensor wouldn't know the difference.I would try a new fuel filter first. Then if you have the means to tap into the fuel system I would measure the actual pressure to see what it is under all driving conditions, especially when the engine quits.Unfortunately, all codes being set indicate a fuel pump or a wiring issue (high resistance) going to the pump.
Old Oct 8, 2022 | 01:13 AM
wundrgrl77's Avatar
This video is same year as my truck and all of the exact same symptoms to a T. The symptoms happen at random even as slow as 20-30km. I have had the rpms drop to almost a stall while idling at a stop light. But then will run incredible for a week with no symptoms at all.
Old Oct 8, 2022 | 04:58 AM
raski's Avatar
If you are convinced, then go for it. People usually guess and change out a component which they least understand.
Old Oct 8, 2022 | 07:21 AM
Unless you can get the exact fuel pressures which one minute the code shows is too low then another code says too high could very well be that sensor providing incorrect info.
A fuel pump driver module could be on it's way out.
Does your equip provide the desired and actual fuel pressures for conditions?
A thorough check of all power and grounds for the fuel system should be performed before just throwing parts at it.
This could be a little more involved that you realize. The choice to have an experienced shop look into this might be a worthwhile consideration.
Mendell
Nov 1, 2021 05:14 PM
jsorto1
Apr 25, 2021 04:44 PM
mbenson1
May 7, 2020 02:34 PM
saemetric
Jul 23, 2015 01:41 PM
30ford
Aug 22, 2011 08:40 AM
