no blow heat or ac
Old Nov 29, 2007 | 03:18 PM
achandler's Avatar
Default no blow heat or ac
94 explorer does not blow replaced blower motor resistor and tested blower motor still no heat or ac help
Old Nov 30, 2007 | 01:18 PM
oldtimer35's Avatar
Default RE: no blow heat or ac
If this is a manual a/c system, then the blower speed switch is the ground for the system. Fire goes to the motor first, then the resistor, then the switch. Do you have power to the blower motor?
Old Dec 6, 2007 | 07:26 AM
achandler's Avatar
yes there is power to blower moter we can hot wire it and it works
Old Dec 10, 2007 | 12:29 PM
oldtimer35's Avatar
If you have replaced the resistor and tested the motor, the only things left are wiring going to the switch and the switch itself.
Use Common Sense
Jun 25, 2016 01:30 PM
Purplekangaroo1
Nov 12, 2012 01:49 PM
Louie63
Aug 9, 2011 04:40 AM
Ramrod48
May 20, 2008 12:12 AM
JoeBlowRacing
Aug 9, 2005 05:50 AM
