shifting troubles
Old Mar 15, 2007 | 02:35 AM
jdye's Avatar
Default shifting troubles
i have 94 explorer automatic 4x4. its not shifting unless i let off the gas and then give it gas. also when going up an incline it downshifts. i replace the transmission filter and that was no help. was wondering if maybe the vacuum diaphragm could be a posibility or if i have to take it to get scanned. thank you
Old Mar 15, 2007 | 03:39 PM
goinstrong's Avatar
Default RE: shifting troubles
Vacuum modulator (diaphragm) or bad clutch plates inside the transmission are two likely suspects. It's supposed to downshift when going up an incline if it's fairly steep. It should only shift down a gear until you reach the top of the hill and then should shift back up. If the engine isn't pulling hard to get up an incline your detent cable may just need adjusted. Bad clutch plates could causeALL the problems you just mentioned though - so if you have high miles I'd plan on a rebuild (or just some new automatic transmission clutch plates and the proper snap rings).
kahuka199
Jan 17, 2006 11:53 PM
dajp
Dec 24, 2005 03:46 AM
IntergalaticMAN
Aug 6, 2005 09:03 PM
deedee3371
Jul 23, 2005 12:53 PM
Hiram
May 13, 2005 03:53 AM
