Squealing Sound
Old Aug 6, 2025 | 04:08 PM
Rog's Avatar
Rog
Default Squealing Sound
Hi Everyone, I have a 2013 Explorer, V6. I noticed in the last couple of days, from a cold start to about 10 to 20 minutes into the run, a fairly loud squealing sound. Coming from the front end area. It is more pronounced while under load, quiet when idling at a stop. I have changed the Tensioner and Belt today and it is still doing it. Alternator is less than a year old, AC Compressor is about a month old. So I would think those pulleys would be OK. checked the Brakes and they are all good. Any ideas??
Old Aug 6, 2025 | 06:30 PM
Sometimes this helps, Loosen the belt, rotate each pulley, AC, Water pump, Idler on tensioner, and Alt. We try to feel for any roughness in their bearings.
Old Aug 6, 2025 | 06:46 PM
Rog's Avatar
Rog
Hi, Thank you for your reply. When I replaced the Tensioner and Belt, I checked the Pulleys on the Alternator and AC Compressor. Both felt good, smooth spinning.
Old Aug 7, 2025 | 03:42 PM
Rog's Avatar
Rog
I have since replaced the front rotors and pads, thinking I might have glazed them, that did not fix the problem.
Old Aug 7, 2025 | 05:17 PM
Is there anyway you might have someone wait and listen if the squeal is louder on one side or the other. That would help narrow down the area to do further checking.
Loudnoises
May 8, 2024 12:39 PM
Edgar J
Apr 7, 2013 04:58 AM
Cj Hutchinson
Jan 19, 2013 07:37 PM
doowron21
Jul 13, 2007 07:05 AM
TexFordOwner
Jun 16, 2005 01:32 PM
