Test camshaft position sensor 95 explorer
Old Aug 25, 2019 | 10:46 PM
Mangus17's Avatar
Default Test camshaft position sensor 95 explorer
I have looked everywhere and can't find a solid way to test a camshaft position sensor on a 95 explorer 4.0 ohv
Old Aug 26, 2019 | 02:58 PM
If you want to,
Can we ask why you suspect the cam position sensor ? Maybe we can help keep expenses down.
Old Aug 26, 2019 | 03:13 PM
Mangus17's Avatar
I got 2 codes from the sec, 214, 628, crankshaft position sensor, fuel pump, fuel filter, coil pack, wires and plugs changed, iac is alright, what could it be?
Old Aug 26, 2019 | 10:51 PM
You could check the CMP connector for VPWR, GND present, but the PIP signal-signature would need to be checled by its waveform produced under normal ops. Checking for connector or pin issues, as well as harness shorts/opens back to the PCM would be the next step, more so if you install a new CMP and the code resets...
628 is TCC excessive slip detected..
Christian James
Oct 31, 2019 07:28 AM
Explorher69$
Sep 5, 2017 11:45 AM
kevinbarnhill
Apr 23, 2011 07:40 PM
designated driver
Jun 30, 2007 05:20 PM
bbb
Dec 13, 2005 11:31 PM
