Transmission jumped out of Park
Old Aug 15, 2006 | 12:40 PM
mets721's Avatar
Default Transmission jumped out of Park
The other day my 2005 Explorer was parked, idiling, with the a/c on for about 45 minutes. The vehicle then suddenly rolled forward, about 8 feet, up a 15 degree incline. A fence stopped the vehicle from going into a pool. There was no real speed to it, the fence did not even scratch the vehcile. When we opened the door to turn the vehicle off, it was still in "Park". The service department doesn't believe that this happened, I was told "No way, that is impossible". I have at least 50 witnesses to the incident. Nobody was hurt and no damage was done. I'm just trying to see if anyone else has had this happen or heard about it happening.
Old Aug 15, 2006 | 01:19 PM
Mulletman's Avatar
Default RE: Transmission jumped out of Park
I have never heard of this and have been working on Fords for some time now. Does the shifter act normal now?
Old Aug 15, 2006 | 01:45 PM
mets721's Avatar
Yes, everything works fine. The shifter never moved, it was still in "park". I'm a Police Officer and if someone ever told me this at an accident scene, I would be quite skeptical; but it happened.
Old Aug 15, 2006 | 03:11 PM
94 4x4 ranger's Avatar
I have read your post and found a TSB (techinal service bulliten) on the shift linkage.So I assume ford is aware of the problem. But the TSB states.Hard to shift from drive to park.So it may not have been in park all the way. Here is the link. http://www.ford-trucks.com/tsb/tsb.p...-2005/t-042212
Old Aug 15, 2006 | 03:32 PM
mets721's Avatar
I thought about it not being in park all the way, but it sat idiling for 45 minutes and the next gear down is reverse so if it wasn't in park all the way it would have slipped to reverse. Hopefully the service center won't just tell me "we coudn't find anything".
Old Aug 15, 2006 | 03:36 PM
Well print that TSB and bring it with you when you take it in. Also check back in a little while and I will see if there is a recall on this.
Old Aug 15, 2006 | 03:42 PM
Nope no recall's for this but there is some for the exterior light's. Here is the link. http://www.ford-trucks.com/recalls/r...005/d-EXPLORER
Old Aug 15, 2006 | 03:44 PM
mets721's Avatar
I will, thanks for the help.
Old Aug 15, 2006 | 03:56 PM
No problem let us know the outcome.
maxpower
Jun 24, 2013 08:58 PM
lori5301
May 9, 2007 12:48 PM
93f250xlt4x4
Nov 5, 2006 05:42 PM
cjc4x4
Apr 20, 2006 04:22 PM
highpowerd2003
Oct 11, 2005 04:25 AM
