04 XLT Triton no crank no start
Old Sep 24, 2023 | 05:20 PM
Mickle's Avatar
Default 04 f150 XLT Triton no crank no start
I bought this truck last year. It ran fine for about a month then it would struggle to start. Every time I would turn the truck off it would take longer to start. Then it stopped starting all together leaving me stranded at work and I had to get it towed home. Now every time I turn the key I hear only one click from the passenger side fuse panel. Ive checked every fuse and relay. I’ve replaced the starter. I’ve tested the alternator. I’ve replaced the ignition switch and I put a brand new battery in it and I still have the same problem. Any advice on what I could do next to fix it would be greatly appreciated.
Old Sep 24, 2023 | 07:19 PM
Was the starter at least cranking the engine over for starting ?
If you have some ,try a shot of carb and choke cleaner into the intake , then see if the engine will fire up and start running.
If after attempting to start it and it does not fire up and start running, remove a spark plug and let us know if it is wet or dry.
If wet , then we check for spark. If dry , that would tell us fuel is not getting into the combustion chamber. That could be due to possible fuel pump problem or injector problem.
Need to know which result you get before going further, but I would not replace any more parts unless we determine it is defective or malfunctioning.
Old Sep 25, 2023 | 05:31 AM
Mickle's Avatar
No the starter isn’t doing anything. When I turn the key the only thing that happens is the click from the fuse panel.
Old Sep 25, 2023 | 07:07 AM
What does the anti-theft lamp do?
Clayfus
Oct 7, 2023 08:25 AM
Solar07
Aug 27, 2023 07:36 PM
Grantc1958
Mar 16, 2022 06:53 PM
Godzilla
Feb 2, 2008 09:58 AM
JMurley531
Mar 28, 2006 06:29 PM
