06 F150 5.4l new timing chains and gears but no power to injectors..
Old Sep 27, 2024 | 12:29 PM
It's about time's Avatar
Default 06 F150 5.4l new timing chains and gears but no power to injectors..
I have a 06 F150 with the 5.4l 3 valve and I just replaced timing chains and gears, water pump, and oil pump. When I got it put back together it wouldn't start so I hooked up the scanner, ran a diagnostic test which tells me that I have an open circuit on my injectors for cylinders 1 2 5 6 7 8, I have been told to check fuse # 15 29 and 30 of which all 3 are good. As I've been trying to figure this out I have cranked the starter over quite a bit and there were a few times that I thought it was going to start but never has. Please someone point me in the right direction. I've been without my ride for to long. Thank you in advance.
Old Sep 27, 2024 | 02:11 PM
Do you at least have a test light to use?
With the key on, you should have power to all the injectors.
If you do have power there , then the problem is the ground coming from the PCM. That ground is timed to fire the injector at the proper time.
If it ran before you did all the work, recheck your work for a plug that the pins pushed out or wires not connected.
Old Oct 4, 2024 | 12:33 PM
Thank you, I've got that issue dealt with now, it's cranking and sounds like it really wants to start but won't quite kick in.
Old Oct 7, 2024 | 06:41 PM
Get it started yet ?
Jtwalck
Jan 4, 2024 03:11 PM
Vincent Jones
Jun 22, 2023 09:18 PM
dave104889
Dec 5, 2021 08:02 AM
skysoldier182
May 10, 2011 10:25 PM
xsquid3
Jul 6, 2007 09:30 AM
