1976 f100 breaks locking up when hot after brake booster install
Old Jan 22, 2022 | 07:19 PM
Marc1976f100's Avatar
Default 1976 f100 breaks locking up when hot after brake booster install
After driving a few miles brakes lock up progressively till they can’t move after installing brake booster
1976 f100 in-line 6
anyone know the solution?
Old Jan 23, 2022 | 06:05 AM
raski's Avatar
Front brakes? rear brakes? Why did you have to replace the booster? Give us some more details?
Old Jan 23, 2022 | 01:05 PM
Default Brakes
it had normal brakes originally non boosted.
wanted boosted so added them in.
Old Jan 23, 2022 | 01:17 PM
raski's Avatar
I did some researching and there appears to be several different master cylinders available. One for non power, one for power brakes one front drum another for disc brakes.. That would be worth looking into and trying. Go to Rock Auto's site.
Old Jan 23, 2022 | 02:03 PM
Default Response
i do have disk front drum back
it does seem like the back ones lock up the most.
I’m going to try ordering the other one and putting it on maybe the shop put on the wrong one
Old Jan 24, 2022 | 06:26 AM
After you do all the checking raski suggested, there are at least two more things.
There is a proportioning valve that is supposed to prevent too much pressure to the rear brakes, and if the rod from the booster is too long it will prevent the master cyl from returning all the way and keep brakes applied.
Omar OneDouble Martinez
Jan 31, 2022 06:20 AM
Jim dc
Mar 15, 2016 05:33 PM
91explorer12323
Apr 29, 2007 04:00 AM
pendergrass
Jun 28, 2006 02:45 PM
Damian
Oct 13, 2005 10:13 PM
