1984 300 Inline 6 question
Old Jan 11, 2019 | 12:24 PM
dakelley62's Avatar
Default 1984 300 Inline 6 question
I have a 1984 Ford f150 with a Inline six engine. My question is the valve cover breather is connected to the air intake via a hose. The filter gets soaked with oil, so I know this connection is not correct. Can someone please tell me what I need to do with this. It is a plastic breather with a male 1/2 inch hose connector on it. Do I need to put a different type of breather on it. Thank you, Dean.
Old Jan 11, 2019 | 05:20 PM
jwshanks's Avatar
Sounds like your pvc valve is bad. That will allow pressure to build up in the crankcase and allow the oil to get that far
Old Jan 11, 2019 | 05:42 PM
dakelley62's Avatar
I will replace the pcv valve. Should the breather be hooked to the air intake? My Haynes manual doesn't show any pictures of the setup nor can I find it on the internet. I should also mention that when I disconnected the hose at the air intake there was some water in it. I have not reconnected it. Thank you, Dean.
Javier250
Jun 18, 2019 10:08 PM
09XSCAPE
Oct 10, 2017 02:48 PM
MJSTaurus
Jan 6, 2014 08:05 PM
Andy Schmick
Sep 4, 2012 06:35 AM
whateversclever
Feb 9, 2011 08:21 PM
