1991 Ford F-150 Custom O2 Sensor
Old Feb 28, 2012 | 12:04 AM
CountryMarine452's Avatar
Cool 1991 Ford F-150 Custom O2 Sensor
I'm new to this so I'm taking a stab at it. If it's possable, how would i be able to check an O2 sensor to see if it's the reason for the check engine light on a 1991 Ford F-150 Custom?
Old Feb 28, 2012 | 06:45 AM
You could get an indication by tapping into the sensor signal wire with a digital meter set to the millivolt scale. It should fluctuate between approx. 100 to 900 millivolts.
If it doesn't , there could be other causes, but you might at least see if anything is happening.
It would be best to get the code(s) from the computer then attack the problem from there.
u009374
Mar 29, 2009 07:27 PM
kevcoz
Jun 3, 2008 07:05 PM
phatboi
Aug 24, 2006 06:01 PM
phatboi
Jun 3, 2006 01:03 PM
retread
Sep 8, 2005 05:03 PM
