1994 F-150 XLT Electrical Issue
Old Jun 26, 2021 | 08:40 PM
GrandpaTruck's Avatar
Default 1994 F-150 XLT Electrical Issue
I have a problem with my fuse pump relay fuse popping each time I try to Crack with the battery at full charge. Sometimes even starting but soon after the fuse blow. I been trying to trace wires but my mechanical knowledge is the basic to keep the car on the road. Please help I'm trying to restore Grandpa's Truck.
Old Jun 27, 2021 | 07:46 AM
Could you please explain, "Crack the battery at full charge" ?
Old Jun 27, 2021 | 08:43 AM
So it turns over when the battery is low and it blows the fuse when the battery is fully charged or at full voltage.
Old Jun 27, 2021 | 10:48 AM
So we are on the same page,
When we are attempting to start the engine the starter turns the engine over.
When the engine starts running , it fires up and runs.
Not sure where you are when you say turns over, can you help out here?
If the charger you are/may be using, is causing excessive voltage to the system , it can cause fuses to blow.
If the in tank fuel pump is jammed and cannot operate it will cause the fuel pump fuse to blow..
There are 2 relays that are responsible for fuel pump operation , they are both the same and can be interchanged
There is an inertia switch in the system to prevent gas being pumped out in the event of an accident. It should be located over the tunnel inside the cab to the right of the gas pedal at the firewall. Make sure nothing has been damaged there .
nwachai
May 27, 2021 09:17 PM
Elijah Earl
Jan 14, 2020 11:04 PM
mbenson1
Jul 11, 2012 09:16 PM
saturn
Jun 26, 2010 06:57 AM
judy_bug08
Aug 19, 2007 07:06 PM
