1998 Ford 150 4x4 lower ball Joint
Old May 3, 2011 | 12:52 PM
JoeKovacs's Avatar
Default 1998 Ford 150 4x4 lower ball Joint
Just like the title but I need to replace my front lower ball joint on the driver's side ,Can anyone tell me if it is pressed in or can I just hit it out with a fork LOL .. PLZ help
Old May 3, 2011 | 08:19 PM
Bullitt94's Avatar
I don't know for sure, but most likely pressed.
Old May 4, 2011 | 05:58 PM
way2old's Avatar
Here is what the Ford manual says. I would guess from their manual that it is pressed in.
Ball Joint
Removal and Installation
NOTE: The ball joint is not serviced separately. If the ball joint requires service, the front suspension lower arm or the front suspension upper arm will have to be installed new.
For additional information, refer to Arm—Lower in this section.
For additional information, refer to Arm—Upper in this section.
Old May 29, 2011 | 10:01 AM
Ray L.'s Avatar
I have changed them several times on my 98 i had and my 2000, You can beat them out but you need a press to put them back in. Thats the easiest way I found to do it.
JoeKovacs
May 13, 2011 04:45 PM
cobra--x
Feb 21, 2010 06:40 PM
regalone70
Mar 30, 2009 08:06 PM
cchev
Apr 7, 2008 06:50 PM
frankd
Mar 21, 2008 01:03 PM
