1998 Ford F150, 4.2 L hard start and high idle P1506
Old Oct 19, 2023 | 08:13 PM
Fordf150v6's Avatar
Default 1998 Ford F150, 4.2 L hard start and high idle P1506
Code P1506
I recently purchased a 1998 Ford F150 4.2 v6 164k very cheap. The truck has a hard star especially at cold start it takes three attempts. After it warms up, it still has a hard start, but not as bad and a high idle of 1000 RPM. Exhaust system backfires as well. I purchased a smoke machine. to do a vacuum leaks test. I had ruptured hoses at the back of the intake manifold, and one under the throttlebody easy fix. but I still have a high idle and a very hard start. I have replaced the idle air control valve replaced all the spark plugs fuel filter and cleaned the throttlebody. But no luck. I had a few possibilities on what it could be. I’m thinking coolant temperature sensor
or weak fuel pump or PVC valve throttlebody plate but I don’t wanna buy and replace without any advice. I am really torn on what it could be. Any advice would be great I am so lost lol. Is there a way to adjust idle?
Old Oct 20, 2023 | 06:32 AM
Idle speed is adjusted automatically and what you might consider is; without touching the throttle pedal , start the engine and allow it to reset it's idle speed.
It should come down and adjust itself., just be patient and allow it to do it's thing.
87Mojo
Jun 4, 2019 05:41 PM
lovettdc@gmail.com
Apr 19, 2017 01:01 PM
n.shift
May 31, 2016 07:22 PM
greuelc
Nov 4, 2007 07:50 PM
ChrisK
Nov 3, 2005 07:31 PM
