2000 F-150 Cylinder 1, 2, 3 Missfire
Old Jul 20, 2022 | 09:16 AM
Shadetree1's Avatar
Default 2000 F-150 Cylinder 1, 2, 3 Missfire
Not sure what happened to my last post. I can't seem to find it anywhere. Anyway, I have a 2000 F-150 4.2L I'm working on that runs very rough and shakes. The entire passenger side of the engine is throwing missfire codes and the exhaust manifold on that side remains cool to the touch after a minute or two of running. All the spark plugs are getting spark. I took the valve cover off and discovered that the valve at the very back has a mangled spring. Would just one broken valve spring cause that entire side of the engine to missfire? Thanks!
Old Jul 20, 2022 | 11:51 AM
raski's Avatar
Can you list all codes? The cylinder with the broken valve spring should not affect the other cylinders. How did you verify that spark is present? If you are sure there is spark present at each spark plug, the injectors for the affected cylinders may not be working. Are the plugs wet with fuel? Done a compression test?
Shadetree1
Jul 20, 2022 08:44 AM
Casey Charles
Sep 19, 2019 06:33 PM
strand02
Jul 26, 2010 09:57 PM
black95markviii
Jun 18, 2010 02:11 AM
johnboy
Jul 12, 2005 05:23 PM
