2004 5.4l coolant system pressure test
Old Oct 11, 2019 | 09:48 AM
dsettlemoir's Avatar
Default 2004 5.4l coolant system pressure test
Ok, I’ve scoured the Internet. Is it
even possible to pressure test the coolant system on the 5.4l 3-valve? I can’t find a dang thing.
I’m having heater issues. Like warm now but that won’t work when it gets cold here. If I rev to 3k RPM then it gets hot. Temp gauge is exactly where it should be.
there seems to be little pressure under the cap so suspect a leak somewhere. Changed thermostat already with no new results good or bad.
I do not suspect a head gasket leak at this time.
Old Oct 21, 2019 | 01:11 PM
nytryder's Avatar
Have you ever back flushed your system? The heater core may be partially blocked. Had the same problem yrs ago and the back flush worked for me.
Old Oct 22, 2019 | 01:51 PM
After all it is 10 days later, but if the heater core is filled even partially with air , it will not produce sufficient heat.
With the engine idling just remove the upper heater hose slightly to allow the air to be expelled. If trapped air is the problem you should see an immediate difference.
bradleyheathhays
Dec 17, 2018 01:03 AM
Christian Butter Poulin
Dec 12, 2018 06:53 PM
Amanda Eldridge
Jan 14, 2017 08:31 PM
Steve16
Jan 26, 2011 11:42 AM
heatstroke
Dec 11, 2005 06:50 PM
