2004 F150 no crank no start
Old Mar 16, 2021 | 01:45 PM
Tom Robinson's Avatar
Default 2004 F150 no crank no start
Intermittent no turnover no start. Now it won't start at all. Troubleshooting the best I can with a test light and found no power at the starter from the ignition switch. Fuses appear to all be good power to everything else in vehicle. I believe it's the ignition switch but I don't know what else to test. Any suggestions
Old Mar 17, 2021 | 02:31 PM
If it is an automatic trans, have you tried both neutral and park positions to attempt to start engine?
Old Mar 18, 2021 | 05:58 AM
I did try that, even though I changed out the neutral safety switch about a month ago. Thank you for your reply. I was able to jumped a solenoid and it started and ran. After I did that I was able to start it several times without any trouble. I'm going to replace the starter which has a solenoid attached.
Old Mar 18, 2021 | 06:24 AM
If the vehicle has some high mileage , it might be wise to replace the starter assy.
Keep one thing in mind , however, you confirmed no power was getting to the starter solenoid and that condition can prevent a replacement starter from working also.
This is what we call "Getting to the root of the problem".
There could still be a problem with the ign sw, the wiring , the MLPS , manual lever position sw. formally known as the neutral safety sw. and you know how these things go , when you are in a hurry, dressed to go somewhere now the problem resurfaces
.Might be a good move to plan your test points ahead of time to determine just where you might lose the power from the ign sw to the solenoid.
Nvshell1
Aug 6, 2020 09:41 PM
vlbh81
Jul 4, 2020 01:40 PM
Sb2957
May 1, 2019 06:50 PM
Jcurtis
Feb 8, 2013 08:24 PM
OFC.B
Jan 15, 2009 10:25 AM
