2005 f150 steering wheel is off center 90 degrees
Old Jun 16, 2024 | 08:43 PM
Lawsonland's Avatar
Default 2005 f150 steering wheel is off center 90 degrees
My son just bought a 2005 f150xl 4.2l and the steering wheel is off by about 90 degrees. It drives straight and no pulling. I look underneath and see no obvious issues. They previous owner said they hit a curb. Looks like the shaft goes straight into the rack & pinion, can this be reset or have to replace
Old Jun 16, 2024 | 09:00 PM
Best to have a qualified shop check the entire steering system. Could be a bent part or maybe somebody already replaced parts and did only half the job..
Do the tires show any signs of unusual wear ? An alignment may be required.
Old Jun 21, 2024 | 09:36 AM
BruceA's Avatar
We used to adjust the steering wheel position by adjusting the tie rod ends, it will require an alignment if you do this, a good alignment shop can take care of this issue.
Sarah D.
Jun 12, 2019 07:06 AM
Luis0227
Feb 19, 2016 12:07 PM
brokentierod
Aug 17, 2011 10:23 PM
oscar7777
Sep 6, 2006 09:08 AM
offroad72762
Dec 2, 2005 06:37 PM
